Need help with wifi antenna/router
FreeBoxes
I have a Signal King 48dbi external wifi antenna that I am using to pull in wifi from free hot-spots in my neighborhood (starbucks,library).
the actual pc hooked up to it has great signal but I can not pull in wifi on other devices in the rest of the house.
is it possible to use the external antenna and route the signal either using a ethernet router (netgear wpn824) or the built-in wireless adaptor in my laptop?
here is a crappy diagram of what i want to do,or something similar. Thank you in advance.
What you call Antenna is a Wireless USB card (all of them have Antennae).
The two links above give you a Wireless or Wire solution for software Routing from the USB card to the second card in the computer.
Read and decide howto, it is Not "Scary" it is rather simple.
