need help with website - netscape users
JoPh
my boss told me when he use's netscape and put his mouse cursor over the rollover image for the menu, they turn black. so i was wondering if someone could help me figure out what is causing the rollover issue. i think it might be the code i got from frontpage.
i should really just tell him to use IE. oh well.
he is also running win98. i am not sure what v. of netscape though.
linky for the website
Sorry no earlier versions of Netscape than 7.1 on my machine.
No rollover issues here... looks fine. Although, you should use Flash for cross-browser compatibility anyway. 😉
could you take a screenshot, so i can see what it looks like
ok, well i told rh71 suggestion and made a flash menu. just put it on the index.htm file right now. still tweaking it a little bit.
