I'm trying to hook up 2 Voodoo2's in SLI.
The problem is their different makes. A C.L and a STB.
I tried using some reference drivers I found on the net, but when I install them and re-boot. It shows that no
drivers are installed. The main graphics card is an Isa cars if that makes a difference.
Could use a little advice and or a link to some drivers that might work.
Thanks,
Rick
Thanks,
Rick
