Need help with vi on iPhone
everman
11,288
I'm using ssh to edit a file on my iPhone that runs a command to disable edge. Here's how
The problem is that when I try to save the file I get the error: "E212: Can't open file for writing"
Yes I'm logged in as root, I even did su root before running vi. As far as I can tell this is a problem associated with not being logged in root, so I don't know why this isn't working.
I'm not very proficient with bsd (on the iphone), so I'd appreciate any help, thanks.
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
Try w! (dubya bang) aka "Write dammit!" which overrides most read-only attributes.
kamper
5,513
Filesystem mounted ro? That's not uncommon on small flash based devices.
