switlikbob
Hello all...here's my situation:
I have been using Kazaa Lite for a few months with no problems. THe other day, I was downloading some things (I usually download all my search results and sort threw them when they are downloaded) and when I was cleaning up the garbage, I ran accross 4 files (20K each) that I couldn't delete. Needless to say, they are still on my computer in the shared folder. I removed Kazaa, checked all the regisrty setting to make sure there were no traces of the program or any kind of crap in the "RUN" key. Then I attempted to remove the files with a few different file shredder programs...no luck...I booted into safe mode (Win2000) and tried to wack them that way...no luck...I wrote a batch file to delete them on startup (using the RUN key)...no luck...I have NAV with the latest defs, no sign of any virus on scans...when I try and delete the files in regular Windows 2000 mode, nothing happens, and I mean nothing...no error...no pop-up window that says the files are in use....just nothing. When I try and look at the properties, I get a message that the "propeties for this item are not available"...the other thing is, the files seemed to rename themselves...they had 2 different names, on rebottm they named themselves the same thing...I did find references to the old file names in the registry, but I wacked those keys and nothing seems to be recreating itself on reboots (which seems to be good)...the only thing that I can think of that I didn't try yet is buying NTFS-DOS to access the files in dos mode and deleting them that way...by the way, I tried to attrib them in command line mode, but they had no attribues according to the error I got...the file name is something crazy like "Pokemon Limp Bizkit Brittney Spears" and some other random profanity...has anyone run into this before???? When I get home, I am gonna try and run some of the symantec virus removal tools, but that's gonna be a shot in the dark...Please help...thanks in advance!!!! bob
