Need Help with V5 5500 and FSAA problem
ZZZZZZ
I need need help figuring out a problem with FSAA on my V5 5500.
I can only play MS CFS (1), Rogue Squadron, Command and conquer with my V% set at single chip.
If FSAA is enabled at all, Fastes, 2x or 4x My computer hangs with a scrambled screen when I launch the game. with CFS, I can get to the menu an play missions from a window but if I go to full screen mode it immediately hangs with a scrambled. The same results are obtained as soon as the game is launched with the other games with FSAA enabled.
Another problem shows up in Rouge Squadron even with single chip selected. The game runs choppy, ther are 2 targeting crosshairs and the picture quality is poor.
Any help woulld be greatly appreciated.
System Specs:
Abit KT7 w/ Tbird 800 no OCing
256 PC133 RAM
300W Enermax PS
20G Maxtor ata66
V5 5500 AGP
SB Live
Adaptec 1506 SCSI controll
3Com 3C905 NIC
40x CD ROM
Sony CR-145s SCSI burnner
SCSI ZIP 100 Internal
56k Internal modem ISA
Windows ME
3DFX drivers ver 1.04.0
DirectX 8a
Average CPU temp= 59°F
Average Case temp= 98°F
(Good cooling fans)
can you be absolutely sure that the V5 is working in dual chip mode on other games? do you have benchmarks to show? what driver and OS are you using?
As a matter of fact so far i had tried out 4 games and none have worked with FSAA enabled. they work in single chip mode only and one, Rouge Squadron, has problem even then.
OS IS windows ME and driver are the latest from 3DFX's Website,( not the beta ones though)
No benchmarks. I don't have any benchmarking applications. any suggestions?
Yep, Just got it. First VOoodoo since I had a MonsterII.
I haven't underclocked it yet, gues thats something I can try. I was planing on trying the Beta drivers tomorrow. I'll check your links as well
Thanks
Edit: Keep the Ideas coming
Thanks again, I'll check it out now,
Keep em coming. BTW for the rest of you out there, Yhis isn't a private convesation so come on and join in....🙂🙂😀
