Need help with typical pc audio solution for school.
bupkus
We have 12 computers in the same area. We can't use the speakers so we need to go to headphones. Sound cards have plug-in jacks of a size I don't know, but they're too frail to go directly to. So... we put a little box on the desk that the kids plug their headphone jacks into. That box has a larger durable plug (just like the headphones) wired to the computer sound card/plug.
You want a laugh? I called Radio Shack. You know the slogan, "you got questions, we got answers." Anyway, if you know how to name the various components I just described please let *me* know. Also, if you know of a place that has durable, over-the-head headphones and the other components that I need, please let me know that, too.
Thanks.
Ok, googled it an found 1/4" audio plugs is the size I want and 1/8" is the size computers use.
Headphone with 1/4" plug goes to box with 1/4" jack. Wires connect to jack and run back to computer and plugs into 1/8" sound card jack.
Now I need the headphones.
Soundcards generally have 3.5mm audio jacks, while larger headphones/microphones often use 6.5mm plugs. These are generally the two standard sizes. Adaptors between these sizes can be bought/made for only a few dollars.
There are also 2.5mm plugs, often used in small things such as mobile phones and MP3 players.
Hope that's helped.
RoD
Or more commonly known as 1/8 inch and 1/4 inch
Professional headphones usually come with the 1/4 inch jacks
Yes the mm sizes for audio plugs/jacks are approximations. They are standard english sizes that were around long before metricification reared its ugly head. So it's 1/8" and 1/4" if you want to be accurate.
Even the small size you call 2.5mm may have been around long enough to be English original too - 1/10" maybe?
.bh.
