Need help with the HAF XM
AJCpar
Hi guys! I've been working on my first build, and I've been having some problems with my case.
I am using the H100 as my cooler and I am planning to move the 200mm included fan fron the top to the side, but I can't seem to find how to attach it to the side (yeah stupid, I know...). None of the included screws work, and I'm lost on how to do it.
Also, I want to use the H100 in a push-pull configuration, and I was wondering if it would fit in my case with an ASUS P8Z77-V Pro motherboard. I don't think the heatsinks on the motherboard will get in the way, but I don't know.
Thanks for the help guys!
For that you would have to use a standard black case screw. The case does come with a few of them. At least mine did. Or you could try to use the clips that hold the 'filter' in place
Great case. I use the optional side window panel with red leds inside. I'm thinking the best cooling for it might be to switch the top two fans to intake, for a positive case pressure.
I thought about getting the window side for mine, but i'm just going to cut and fit some plastic there. Currently I have my radiator mounted to the top with an intake setup. Its a great case
