Need Help With Temps and Over Clock
LiquidFlame
130
Well I got my RMA?ed MB a couple of days ago so I decide to hook it up. I should first off say that I?m using a old GPU that I have (GeForce MX 4000 PCI) until my RMA?ed GPU comes in the mail, so the one in my sig is not in my rig right now. Originally when I did my first over clock to 3GHZ I had these settings with the following temperatures after running Prime95 for an hour:
Set FSB to 1333Mhz
link and sync RAM
Set RAM timings to 4-4-4-12 2T
CPU voltage = 1.35v
FSB - 1.3v
Mem - 1.9v
SPP - 1.4v
MCP - 1.525v
SPP-MCP - 1.35
Room: 75.7 F
Core0: 61.8 C
Core1: 61.4 C
Core2: 56.7 C
Core3: 56.8 C
As you can see, these temps were not that good, and I couldn't really figure out why I was getting such high temps. I decided when I was putting my motherboard together, I was going to go all out with the mod?s that I felt comfortable with. I lapped my HS and CPU, which came out pretty well. I also did the vdrop mod, and I replaced all the TIM on the mosfets and NB/SB which I have always done. Now the original temps that I had, I wasn?t too happy with so I was hoping the lapping would help. I ran Prime95 for about an hour with the same BIOS settings as above, and I got the following temps:
Room: 75.7 F
Core0: 65.9 C
Core1: 65.9 C
Core2: 60.39 C
Core3: 60.55 C
As you can see the temps got worse, and after about an hour, my computer crashed with a blue screen saying "Hardware Conflict, contact you hardware vendor". I have never seen this error before, so I?m not sure if it?s because of the crappy GPU I?m using. I have all my system fans running on 100%, and I?m really concerned that I may have done something wrong when I was lapping my CPU and HS.
I decided to go back to regular stock speeds, and ran Prime95 for 3 hours plus and I haven't had any crashes, these were the temps that I got:
Room: 77.5 F
Core 0: 55.44 C
Core 1: 54.52 C
Core 2: 48.95 C
Core 3: 49.05 C
I am using AS5 on my CPU, and I know the AS5 has a 200 hour burn in time, but I don't think these temps should be that high. Can you guys please help me with my temps. I?m not sure what I?m doing wrong. Thanks for the advice in advanced.
Idontcare
21,110
59
A G0 with a Tuniq as you have, running a Vcore of 1.35V (is this bios/idle/load?) and is OC'ed to 9x333 = 3GHz will see Temps in the high 50's °C to low 60's °C.
I have a G0 (VID 1.2875V) that requires 1.3750V (Bios set) to be Prime95 stable with small FFT on a Tuniq120 at 9x333.
The temps during load (per coretemp) were ~57°C across the cores with a load Vcore of 1.2800V (Vdroop is very high on my DS3L).
BonzaiDuck
16,327
1,888
Your original temperatures were fine at 76F room ambient. Just fine.
I'm not familiar enough with the EVGA mobo -- I have the Asus Striker -- same chipset. Early last year, a friend and I had speculated and anticipated removing the copper heatsink "necklace" from the chipsets and mosfets, replacing the TIM with AS5 or a micronized diamond paste.
We're glad we didn't do it. Apparently, on the ASUS board, the TIM is part of a glue - just short of epoxy. You run the risk of damaging the board by removing the copper heatpipe cooler (and what I meant in first sentence -- I don't know what onboard cooling your EVGA provides, or what it looks like.)
You HAD the right temperatures, and probably improving airflow and case exhaust would've improved them. I have a B3 Q6600, and with a lot of attention to cooling with my U-120-Extreme, it was showing average core (TJunction) values close to 65C with room-ambient at 79F.
But this would mean a TCASE temperature of closer to 55C -- several degrees below the throttling point, and well within the Intel spec.
LiquidFlame
130
I just don't understand why I'm having so many problems just trying to got it to 3GHZ. My chip should be able to easily do that without any problems.
