I used to stay up on computer builds and use my tax refund to build off pcper's leaderboard each year. As you can see, two children later have stopped any upgrading for the past four years. Below is my last build and my motherboard crapped out. After searching high and low for the same board, apparently they are like hens teeth. Can anyone let me know of a different socket 775 board that is currently available that I can use the rest of my hardware on? It doesn't need to be SLI. Again, the plan was to use it, but the money had to be used elsewhere. Thanks in advance for your help!
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
NEC Black 1.44MB 3.5" Internal Floppy Drive - OEM
LITE-ON 20X DVD±R DVD Burner With 12X DVD-RAM Write Black SATA Model LH-20A1S
Seagate Barracuda 7200.10 ST3320620AS 320GB 7200 RPM SATA 3.0Gb/s 3.5" Hard Drive (Perpendicular Recording Technology) -Bare ...
Antec True Power Trio TP3-650 650W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply with Three 12V Rails
EVGA 640-P2-N825-AR GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card
ASUS P5N32-E SLI Plus LGA 775 C55+MCP55P; a.k.a. nForce 650i SLI & nForce 570 SLI ATX Intel Motherboard
Patriot Extreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model PDC22G6400LLK
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 65W Dual-Core Processor BX80557E6600
