Need help with Statics HW...
JohnCU
Banned
figure 2.60
Knowing that portions AC and BC of cable ACB must be equal, determine the shortest length of cable which can be used to support the load shown if the tension in the cable is not to exceed 725 N.
The part that is throwing me off is the tension in the cable. Are they talking about the tension in AC or BC or what? or is it 362.5 in each one? I think this has something to do with isosceles triangles, but I can't figure it out.
Listen, you have three equations in all of statics. One of which you don't even need here. Sum the forces in X and Y. If you don't know how to break a force down to its components, then well....
right, but then you have a 1000 N force going down, so how can you only have a 725N force going upward?
yes, they do cancel. and the two forces in the Y direction = 1000. and another hint is that statics is almost all right triangles, not isosceles
a cable only has one tension, at least for theoretical problems like this.
and you need to learn your trig before you get to imaginary numbers, which are needed for all of your AC circuit analysis.
so now you have two unknowns in that equation. where can you get another equation so that # unknowns = # equations.
i always think of force vectors as ratios. it isn't directly correlated to percents, but you can think like, so much of the force goes in X, and the rest goes in Y. the geometry is what gets you those ratios.
yeah Fa(1.5/A) + Fb(1.5/B) = 1000 N, I've had that equation for an hour now but don't understand, since the tension can only be 725 N in the cable, how is it gonna support 1000 N?
i'm an EE, i shouldn't have to do this kinda crap.
Haha, I say the same thing. Statics + Dynamics this quarter since I was too lazy to take 3 years ago.
