group of boys average height 170cm, standard deviation 8cm.
group of girls average height 160cm, standard deviation 8cm.
will the standard deviation of the 2 groups together be greater than 8cm??
The standard deviation is the average distance from the mean.
Since it's a modulus quantity (doesn't matter whether distance is + or -) I think it will increase. My stats is somewhat rusty though.
