Need help with SSD issue
Lemonparty
10
I just recently installed windows 7 on 60 gigs of partitioned space on my macbook pro's SSD. Everything was running fine yesterday as I installed steam and fallout 3. I try to run it today and install another game on my drive and the system is showing me that I only have 5 gigs of free space. I think to myself. "thats not right" so I look it up and some people were having issues with SSD's on windows 7 so I run through all of there fix's to no avail. none of my files are hidden and I did a search in explorer for what might be taking up the space. The largest file is fallout and its 5 gigs not sure whats going on but if anybody could help that would be great.
sbpromania
265
www.sbp-romania.com
Hello,
Have you tried to inspect your hdd with a space monitoring tool? For example: TreeSize
If could be your hibernation files that are eating so much space.
Dahak
3,752
25
Generally Page File and Hibernation file are the usual space hogs, another thing you can do is run disk cleanup and click on the Clean up System Files which will clean up all the old windows updates files, but it removes then completely from the system so you will not be able to uninstall any of them
Lemonparty
10
Thank you it was the Hibernation file's. Also windows eats a ton of space I forgot about that
