Hello!
I'm a bit confused, and could use some help. I have a new Agility 60GB SSD w/ Windows 7 64 bit. About 30GB installed on the drive. I want to move a few directories to a separate drive.
C:\Users\myname\AppData\Local\Temp
C:\Windows\temp
Downloads
Music
Pictures
Videos
I've read :
"You can minimize the amount of “relocation confusion” that might occur by using something like “Junction” to hard-link the directories to a different device rather than messing about with registry entries."
I downloaded Junction, but can't figure out how to set this properly. I also read I can use MkLink. I don't know how to use that.
If anyone can explain this, or offer another utility to accomplish this I'd appreciate it.
Secondly:
Question? How would this process effect my back-up using True Image? I'd only want to Back-up the actual SSD, not the moved temp folders? Any Experience? Will True image just back-up the external drives folders?
Thanks for your help!
Maxi
Did some googling and found a utility that can set up links but there really aren't any instructions: http://code.google.com/p/symlinker/
C:\Windows\temp
Downloads
Music
Pictures
Videos
I've read :
Secondly:
Maxi
