Need help with SQL statement
milehigh
951
set strCats = Request.QueryString("cats")
sqlCats = "SELECT * FROM subCats where ID = strCats "
ID is an autonumber primary key in an Access DB.
I've tried it as
sqlCats = "SELECT * FROM subCats where ID = '" & strCats &"'"
It works if I enter as....
sqlCats = "SELECT * FROM subCats where ID = 2"
I tried strCats=Cint(Request.QueryString("cats") as well and that didn't work either.
Any suggestions??
KLin
29,556
163
You're trying to compare a number to the string "cats". You need to use the the field that contains the text "cats" in the where clause.
So something like sqlCats = "SELECT * from subCats where Description = '" & strCats & "'"
EDIT: Those are single quotes in the where clause BTW to qualify it as text ;).
milehigh
951
After my hosting company 'suggested' I do my troubleshooting locally I finally get it figured out.
Thanks for the reply!!
