- Apr 29, 2005
- 5,649
- 0
- 0
I am trying to query WebTrends database tables.
Currently, when pulling active profiles names from one table and datasources from another, I get a list of each profile associated with each datasource parameter. That is not quite what I need though.
What I need is to compare those results against a third table that actually has the profile/datasource mappings so that the results show exactly which profile is using which datasource(s). Here's what I have currently:
I did have a LEFT JOIN and changed it to RIGHT JOIN to see if the results would be different (they weren't).
The third table is wt_ProfileDataSource which has two columns; DataSourceID and ProfileID. I don't have it in the query above b/c I am very new to SQL and I'm unsure of how to include it to compare against to get the desired results (the above query only showing a list of profiles with their actual mapped datasources (the contents of the third table) instead of a full list with every profile being displayed as if they were mapped to every datasource)
Thanks in advance for any help that comes my way.
select distinct TOP 1000 wtp.ProfileID
, wtp.ProfileName
, wtp.WRC_ProfileID
, wtp.TimeZoneID
, wtd.DataSourceID
, wtd.DCSID
, wtd.Name
From wt_profile wtp --, wt_DataSource wtd
RIGHT JOIN wt_DataSource wtd ON wtp.AccountID = wtd.AccountID
where wtp.profilestatusid like '1' or wtp.profilestatusid like '8' and wtd.DCSID like 'dcs%';
The third table only has two columns that it uses to map the profile to datasource: DataSourceID and ProfileID
