I'd appreciate any help you guys can give regarding my problem.
Currently, I have my cpu fan connected to my cpu header. It's a PWM fan and my board has a 4 pin header and it can run in both PWM/voltage control.
The problem is, the fan is spec'd to max out at 1300 rpm but when I use the manual fan control through speedfan, it maxes out at 700 rpm. I thought maybe the rpm gauge might be faulty for whatever reason, so I plugged the fan to one of the 3 pin fan headers on my mobo. Now speedfan showed the fan running at 1300 rpm and the fan itself was noticeably faster/louder in it's operation.
Does anyone have any insight on why my fan is unable to get the max rated rpm when plugged into the cpu header? Keep in mind that I was running speedfan in manual with 100% PWM when I plugged it into the cpu header. The fan in question is a Thermalright TY-140 in place of my CM 212+ fan if it matters.
