- Mar 1, 2000
- 5,096
- 20
- 81
Hey guys, i've been working on upgrading my HT recently. I started off with a home theater in a box from panasonic, it had decent sound but lack of inputs got me to pick up a better receiver.
Now i have a Yamaha HTR-6030 5.1 Receiver and im looking for better speakers. When i switched from the Panasonic to Yamaha i picked up a Polk PSW10 Sub, which is doing the job for my living room size.
Im still using the 5 set of Panasonic speakers which these specs are from the manual:
Front:
Type 2 way, 2 speaker system (Bass reflex)
Speaker unit(s) Impedance 4 ohm
1. Woofer 6.5 cm (21/2z) Cone type
2. Tweeter 6 cm (23/8z) Cone type
Input power (IEC) 90 watts (Max)
Output sound pressure 81 dB/W (1.0 m)
Cross over frequency 6 kHz
Frequency range 82 Hz?41 kHz (j16 dB)
95 Hz?40 kHz (j10 dB)
Dimensions (WtHtD) 252 mmk1123 mmk234 mm
(929/32zk447/32zk97/32z)
Mass 3.7 kg (8.2 lbs) - from the floor standing speaker base, these speakers are definitly not 8.2lbs
Rear:
Type 1 way, 1 speaker system (Bass reflex)
Full range 6.5 cm (21/2z) Cone type
Output sound pressure 80 dB/W (1.0 m)
Frequency range 96 Hz?25 kHz (j16 dB)
120 Hz?22 kHz (j10 dB)
Dimensions (WtHtD) 92 mmk135 mmk95.4 mm
(35/8zk55/16zk33/4z)
Mass 0.75 kg (1.65 lbs)
Center:
Type 1 way, 2 speaker system (Bass reflex)
1. Full range 6.5 cm (21/2z) Cone type
2. Full range 6.5 cm (21/2z) Cone type
Input power (IEC) 320 watts (Max)
Output sound pressure 84 dB/W (1.0 m)
Frequency range 105 Hz?25 kHz (j16 dB)
125 Hz?22 kHz (j10 dB)
Dimensions (WtHtD) 270 mmk92 mmk95.4 mm
(105/8zk35/8zk33/4z)
Mass 1.25 kg (2.75 lbs)
Considering those specs, would these be considered a decent upgrade? Polk RM10's or RM75, RM85s??
I mainly use my receiver for my PS3 (movies and video games) and my Zune for music.
Front:
Rear:
Center:
