Need help with some ip addressing / domain joining
WinkDk
Hallo.
Case: I have 2x windows server 2012 R2 and 1 windows 7 pc as klient.
My problem is that i can't join the klint to the domain that's running on server1.
Server 1 is set up with ad and dns, etc.
Link to screenshots of what my problem is and some info:
http://imgur.com/l3YBgxU,JXKwrhq,uWYIqaz,AZzovfv
There are 4 images (switch between them in top, when vieweing the link)
The client needs to use server1 as its DNS server (or use a DNS server that is configured to answer properly for the domain in question.)
It does not appear to be configured that way, however. Change the client's DNS server to use server1 and you should be able to join.
Thanks alot for the help drebo.
Changeing the dns address on the client to the ip of the server, solved the problem.! 🙂
Have a nice day 🙂
