Need help with simple regex pattern matching
I need to match a comma and any number of spaces and replace it with one space. The closest I can come up with is [,\s*] but its not interpreting correctly. Where am I going wrong?
if you used [,\s*] literally (including []) as your expression then you defined a class of characters to match, not a sequence. Basically regex will check for anything matching in the set regardless of order. You can define a group, or sequence, by using () instead or nothing at all as esun shows.
So, [,\s*] will match a single comma or single space (not entirely sure what the * will do in this context and I'm too lazy to look it up). (,\s*) will match a comma followed by zero or more spaces greedily.
Ohh, yeah, Onund is right. If you write [,\s*], it will match a comma, any whitespace character, and any asterisk, which is not what you want.
Please reread what Onund posted.
I did. Aside from the asterisk part, he was right (and he wasn't technically wrong about that, since he said he didn't know). Now what was your point?
