need help with signing a java applet
flashbacck
1,921
I'm trying to have an applet write a file on the client system, but I'm having issues signing my applet. I think I'm missing something and would appreciate any help. Here are the steps I am taking...
1) keytool -genkey -alias blah
2) answer all the questiosn
3) jar -cvf Applet.jar *
4) jarsigner Applet.jar blah
5) applet code in the html file is:
<applet code=Applet.class archive=Applet.jar width="900" height="600">
6) run applet: appletviewer Applet.html
I then get an AccessControlException. What am I missing? Also, why do I still get the AccessControlException when I run my applet through appletviewer? I was under the impression appletviewer automagically gave permissions, and the AccessControlExceptions were only when you tried to run the applet off a server.
Some test code I'm using (AccessControlException at the System.getProperty line):
flashbacck
1,921
it works now in IE7, after I rebuilt the jar and resigned. But it still doesn't work in appletviewer...
MrChad
13,507
Did you import the certificate you generated to sign the JAR into your certificate store (I believe it's another keytool command)?
flashbacck
1,921
er.. no I didn't... But if I generated it, isn't it already in the store?
Additionally, the certificate I generated will apparently only last 6 months. Is there a way to extend it indefinitely?
MrChad
13,507
I'm fairly certain that you still need to import the certificate after generating it. But it's been a while since I had to sign an applet.
You're going to want to purchase a certificate from Certificate Authority such as Verisign or Thawte if you'll be deploying this somewhere.
