Need help with SETI: Want to utilize full potential of Dualies.
Ulfwald
Moderator Emeritus<br>Elite Member
May 27, 2000
8,646
I currently have 2 machines running dual processors, but only 1 seti client. How can I get a second cruncher started?
I have been doing some reading here, and obviously I am not using my machines to their fullest potential.
mastertech01
Moderator Emeritus Elite Member
Nov 13, 1999
11,875
282
You Elites stay outta here.. ;)
I know its pretty easy Ulfwald, as I had it on my dually sometime back.. but damned if I can remember.
Congrats Minendo on your Elite! :D
RaySun2Be
16,565
There are several ways that I know of. :)
1 is to use SETIDRIVER, and set the # of processors to 2
2 is to create 2 separate SETI folders and start SETI from each, so you are running 2 instances of SETI.
There are probably several other ways as well. :)
Shuxclams
9,286
15
use the flexinstaller.... ;)
or create 2 directiries and run one in each
or use setidriver...
SHUX
Robor
I've got a few dualie CPU systems running SETI and the install I use runs hidden and as a service, can do multiple CPU's, and has a quick install/uninstall to remove the service. IMO, the FlexInstaller is the way to go but the uninstall feature is missing. :(
Let me know via PM if you want me to send you the installer I use...
