Need help with SETI@home.
I believe berkly is having problems as of right now. You can either wait it out or connect to a Q.
See this linky here
You can also use seti driver to store extra WU's for you to work on if there are problems.
I had 4 to 6 in que for each of my systems but they go through them really quickly.
As of right now I have about 6 WU that needs to be transmitted and two of my systems are idle 🙁
Only one has anything the crunch and it will be done with that in less then an hour 🙁
I'll use the down time to upgrade my 1U system by installing a second cpu.
You need to enable your Proxy Server setting in seti driver and enter the address and port In this case www.scarieville.com for host and 5517 for port and then save your setting.
Once your're connected to the net click transmit and it should connect to the q and send your completed work units to the q and download new ones from the q.
Berkly is still down at this time by the way
Doesn't SETIQ need to bypass to Berkely for a new users 1st connection? ,or PM them to setup an account manually?
I don't see anything about SETI having problems on their website😕
I know the info is in the SETIQ thread linked by Evadman 🙂
If you contact the queue owner they can transfer wus from one persons queue to another so the passthrough to Berkeley doesn't have to happen.
If you check this page, you can see a list of Team Anandtechs public setiqueues.
You might as well us one thats close to you.. 😛
SetuQueues
