I recently purchased a MSI KT4 Ultra Motherboard (MS-6590) and I have tried to use the serial ATA but every time I my pc boots up it gives me the following error: no drive attached to the fast track controller. Bios is not installed.
When I do hook up the cables to the hard disk raid connectors it gives me the following when I try to boot:
Fast track does not detect the proper interrupts.
Check the PCI IRQ setup and make sure that the pci slot supports the master bus operation.
I have installed every driver that came with my motherboard and in my hardware config in control panel it shows that the fast track controller is installed properly.
Any help would be greatly appreciated.
Thanks
Thanks
