Need help with SD storage for iPaq handheld:
MatthewF01
728
OK So i have an iPaq 3955 with built-in SD slot. I want to have some more storage space for videos, music, and such for playback on my handheld. My friend gave me a 32MB card for Christmas. To write to the card i have to put it in my iPaq then browse to the card through My Device in Explorer. To write a file to the ipaq or the card takes forever.
Recently I was taking pictures off my compactflash card from a digital camera. I have a little hub/reader thing that goes right into the USB port and its really fast.
So I thought I should get a CF expansion for the iPaq and maybe like a 256MB CF card.
However this adds substantial thickness to the device!
So on eBay im looking at 256MB SD cards, as well as SD card readers. If i wrote files to the card using a reader, will I see the same type speed as with the CF? I mean, my current way of doing things, it takes a good 5+ minutes to write a 20MB or so file to the card. So it should pick up if im just writing direct to the card, yea?
Other question: i have nforce2 which is USB2.0 equipped. I saw some USB2 SD readers listed. I wont see any performance out of that compared to a standard 1.1 would I?
thanks!
may
422
1. It is much faster if you have a SD card reader. Moving data through Ipaq's USB connection is too slow.
2. Most readers are usb 2.0 compatible, but does not provide real USB 2.0 support. Real USB 2.0 readers are relative very expensive, compared to the regular usb 2.0 compatible card reader. Search on tomshardware.com. They have a comparison review about USB 1/2 readers.
