Need help with Roxio Easy CD Creator 5
DoubleA
79
I just purchased a burner and my friend let me use his Roxio CD to install Creator 5 Plat Edition.
Basically what I want to do is burn a cd using MP3 files but I burn to the CD, I want them to burn to WAV format without me actually having to do the conversion myself. I've heard this can be done, but can't find any conversion program within Roxio...what's up with that? The burner I have is the VeloCD TDK 12X, but I'm not using their CD Burning Software.
Thanks for the help fellas.
Nov 12, 2001
72
If u install EZCD 5, there should be a project manager - the blue little screen with the big buttons.
So insert a bkank CD in the drive, and it should auto pop up, if it doesn't then just open Project Manager in the EZCD program group at the start menu.
Go to the music section, and select the Music Project thingie *i think thats the name, but it should be fairly easy to figure out which one because the second one goes MP3 music project - You don't want that one, you want the regular music project.*
Once you there, all you need to do is drag and drop the MP3's you need, and voila, go burn it. :)
khtm
2,089
IscareCuzICare is correct, but IMO you should uninstall that sh!tty piece of software and install Nero instead.
Either way, they both give you the option to drag-and-drop MP3s into a project window and burn directly to .cda (cd audio) format, which is how .wav files are burnt onto CDs.
-khtm-
DoubleA
79
Thanks guys. The weird thing is that it doesn't give me any option (or none that I can find) to convert. There is a "Convert" blue button, but it is faded out, rendering it useless even when I have an MP3 file selected. I'll waste a CD and see if it auto converts into into .cda
khtm
2,089
There isn't supposed to be an option to "convert". The conversion from .mp3 to .cda is done automatically when you burn the CD.
-khtm-
