need help with router settings
Siva
Ok, so comcast decided to switch their networks without sending me the crap I need containing all the info on settings, etc.... plus they won't answer their phone unless its one of the incompetant techs who tell you to call a higher tier tech support line. So basically what I need is settings for my router, I can connect fine as long as its not through the router. I need host name (CGxxxxxx-A.whaterver.whatever.nj.comcast.net and i have the CG number), and I need DNS names. How would i go about finding them?
Do you mean your DNS ip addresses? If you can connect directly with your computer fine, then lookup your DNS server numbers when you do this, and then enter those into your router.
