need help with regular expressions
  • Thread starter Thread starter
  • Start date Start date
I'm trying to make the webcrawler that indexes my website a little better.
It allows me to do meta and title rewrites in the index using regular expressions.
my experience with them is minimal
basically all i need is how to extract the text between two tags
example
<h1 class="headline">herty smerty flip flip</h1>
The syntax to do the rewrite is easy, but i don't know how to extract 'herty smerty flip flip' from the code.
This should work.
only works if on the same line, and if the text you want to extract doesn't have any < or >'s.
let me clarify
the source will be full of lots of stuff, but there will only be one <h1 class="headline"> tag (and its closing)
i want to get the phrase thats between that h1 tag and its closing /h1 tag.
can i modify what you wrote to do that?
/<h1 class\=\"headline\">(.*?)<\/h1>/
That might be closer to what you're looking for. Then you want to save the part you extracted (the (.*?)) to a variable, or what?
Rob
