Need Help with Ram
cchen
6,062
I'm having a problem with a 256 mb pc133 stick of high density ram I bought from Mushkin.
This is the configuration:
Duron@600(I had it overclocked @950 but after having these problems I decided to clock back down but still no help)
Asus A7V rev 1.01
BIOS 1005d(had 1007 but some ppl told me to go back because they said after installing the newer versions they had problems)
In BIOS I tried both PC100 and PC133 settings with the Mushkin with my CAS set to 3(default)
Last night I had my Micron PC133 in after redoing Win98SE I played a few games(UT/CS) with no problems then I decided to take out the Micron and put the Mushkin in since thats what I bought it for. After powering my system back up I got into Win98SE and it said I had a registery error and I needed to restart windows so I did.
Well after it loaded again it said the same thing so I got a little frustrated and put the Micron back in then Windows loaded with no problems.
I double checked to make sure the DRam voltage was at default. Also made sure it was in the right DIMM slot.
The mushkin ram gave registry errors on cas 3 100 and 133
Can anyone give any insight into this and how it can be solved?
