Need help with Ram purchase!
Neutralman
77
I am building a new 2500k desktop and need help determining which ram I should buy.
Ram should be newb friendly! (I don't know how to tweak bios settings)
Ram should be reliable!
Should I get 8GB ram or 16GB? Mostly do gaming on 1 monitor.
Should it be 1600mhz or higher?
Budget: No budget limit, but I do prefer good deals!
Your advice is greatly appreciated.
Neutralman
77
You need to post what MB you will be getting.
Thanks sir! Here is the MB I am getting.
Asus P8Z68-V LX Intel Z68 Chipset DDR3
ATX Mainboard LucidLogix Virtu and Intel Smart Response Technology & 7.1 HD Audio, GbLAN, USB3.0, 2x SATA-III RAID,2 3 PCIe Gen2, 2 PCIe X1 & 2 3CI
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Go to the ASUS site and dl the QVL here. It's a good place to start. If you are just gaming and not benchmarking, you will notice no difference between 1333 and 1600 ram.
Neutralman
77
BoomerD
66,728
15,127
Don't worry about getting 1600 speed RAM. The difference is minimal...and it's unlikely you'll ever notice it.
Try to get RAM from the ASUS QVL. It's been tested with the board for compatibility.
ALWAYS buy as much RAM at once as you're going to want...and buy it in sets that have been tested together. Since the RAM manufacturers buy chips from a variety of plants, there's no guarantee that the pair you buy today will work with the pair you buy next week, even if they have the same part number.
IMO, if you want 8 Gb, buy 2 x 4 Gb...not 4 x 2 Gb.
Neutralman
77
Just one more question guys! Some of the QVL ram is listed at 1.65v. I read that sandy bridge works best with 1.5v. The Gskill ram magnus suggested is 1.5v so I am buying that. Just wanted to know if 1.5v is indeed the best to satisfy my own curiosity.
MagnusTheBrewer
IN MEMORIAM
Jun 19, 2004
24,122
1,594
Unless you're pushing the envelope in OCing, the different power requirements don't affect anything.
mfenn
22,400
www.mfenn.com
Yes, 1.5V is recommended for the long term reliability of the Sandy Bridge memory controller. 1.65V will work, it's just not optimal. Since you can find 1.5V and 1.65V at the same price, there is really no reason to get 1.65V.
