- Jun 12, 2003
- 12
- 0
- 0
Hey everyone,
Before I go on, sorry about the long post and thanks for taking the time to read it.
I'm currently using 3x 512MB Corsair XMS modules (CMX512-3200C2) running at conservative timings on an Asus A7N8X Deluxe Rev 2. The CPU is an AMD Athlon XP 3200+ running at stock setting.
I use this computer mainly for higher-end gaming and music production. While I don't want to sacrifice speed, I don't need to push the system too hard because stability is my first priority. (I don't wanna lose all the tracks because of a freeze.)
I'm now ready to do some general upgrades that are both AMD- and Intel-compatible just to keep my options open for future CPU upgrades.
RAM: (Need 2GB or more)
I've had good experience with Corsair XMS and I think I'd stick with it. I'm thinking about the TWINX2048-3200C2 or the platinum version. I was also looking at the XMS XPERT ones (TWINXP1024-3200XL) but I'm not sure getting two seperate modules will give me the same stability as getting a matched pair. Also, they sell matched pairs of the XMS PRO series, but they run at a ridiculous 3-3-3-8. Has anyone had any experience with any of these modules? I'm also open for suggestions coming from real experience.
HD: (Need about 300GB or more)
I got one 120GB and one 160GB Western Digitals (both SE versions). While these are not bad at all, the whining noise is just killing me. And since the PC is being used in a small music studio noise is an issue. I wouldn't mind switching to SATA either if it has significant benefits over the U-IDE and saves me some noise.
Video Card:
I have two LCDs so I need a dual output (preferrably dual DVI) card. Right now I have an ATi Radeon 9700 (128MB) but I'm having a lot of driver compatibilty problems with it becuase of all the non-conventional musical gizmos I have connected to this PC. Windows actually tells me that the ATi driver is causing problems. So I'm thinking about switching to nVidia. I'm willing to pay up to about $400 or so for the video card, this should make it easier.
I'm only posting this to get sme feedback from people who have actually dealt with these parts. I have done a bit of research and will do more meanwhile, but please don't recommend a part if you haven't actually seen it in action or if you just think it's a great product. We all can read the specs and salivate.. :laugh:
Thank you all very much for your help,
Nav
Video Card:
Nav
