Hi There (first time OCer here),
I am OCing my E6400 (on Asus p5w, with OCZ RAM see below), and currently got to 390MHZ FSB or 3.12Ghz internal speed. Here's my settings Vcore 1.3125, ram V 2.15, V MCH 1.6 . By far it looks stable (no formal test performed, but ran some tough programs without problem).
Q1: I have left all the ram setting unchanged, to make it as stable as possible.
At this point , should I keep pushing the FSB to until get to the edge of my CPU, or
start to change the Ram setting , so that to OC CPU and RAM in an alternative
way ?
Q2: I tried to play with Ram setting a bit, but the computer wouldn't even boot after that,
Here is the ram readings before changing ram settings :
"FBS😀RAM 1:1 ; CAS# Latency 5.0 ; RAS# to CAS Delay 6; RAS# precharge 6;
Cycle Time(tras) 18; Bank Cycle Time(Trc) 24"
Following suggestions of some members here, I made the following change:
"CAS 4, RAS precharge 4, RAS to CAS delay 4, RAS activate to precharge 5, write
delay 4, Hyper path 3 Disabled, Dram Throttle Disabled"
Could someone help me out here ? would really appreciate it.
BTW: My Ram is: OCZ DDR2 2GB (2x1GB) PC2-6400 CL 5-5-5-12 Gold GX XTC Dual Channel
best
tong
way ?
best
tong
