Need help with RAID array
passatista
W2K SP3
AMD 1.33 GHz
512 MB 2100 DDR
Promise FastTrak 100 RAID PCI
Two IBM 60 GB 60GXP drives in RAID 0
I have to update the firmware of the 2nd IBM drive in the RAID 0 array (the PCI IDE 1 Master, as opposed to the PCI IDE 0 Master). IBM tech help has sent a DOS updater, which updates the firmware of the 1st drive in the RAID array but cannot see the 2nd drive ? after updating the 1st drive it quits, stating that all drives have been updated, which IBM's Drive Fitness Tool indicates is not the case. Running the updater again just gives the notice that all is up-to-date. Also, none of the Promise array management utilities offer any help.Obviously the updater cannot see thru the RAID controller to the 2nd drive.
I don't want to reformat and do a clean install, so I have a work-around solution, but I have never done this before, and wonder if someone has any advice.
I intend to take the bad drive off the RAID controller, attach it to the primary IDE controller of the ASUS MB, and after changing the boot order in BIOS, boot from the IBM DOS updater, and update the firmware. After the firmware has been updated, I will shut down the computer, reattach the 2nd drive to the RAID controller, again change tho BIOS boot order and everything will function as before. I shouldn't even have to remove the RAID controller from it's PCI slot as the computer will boot into DOS before it sees the RAID card.
Or am I going to screw something up?! Perhaps just attaching the 2nd drive to the IDE controller, or leaving the RAID card in place will alter some setting with the result that I'll have to rebuild the RAID array and do a clean install?
Any advice appreciated.
Obviously this was too trivial for the local cognoscenti. So, thinking that if I had been very wrong, someone would have pointed out my ignorance, I went ahead and did as described above. No problems encountered.
Just got a chance to see this, but usually drive mfrs require their drives to be the only drive on a channel (or perhaps even in the machine) and set to Master to do a firmware update. Their firmware flashing instructions should be very specific on these points. Is it not so? Anyway, congrats on scoping out a way that worked.
.bh.
