Need help with purchasing a new graphic card.
R0H1T
2,582
162
Well I just "switched" it to 5k INR and below :3
You know what you're not looking hard enough & that's because ~
a) You want us to spend that amount of time/effort which you apparently don't wanna do yourself :thumbsdown:
OR
b) You want the cheapest GPU that'll drive a number of games which is simply not possible in that tiny budget D:
either way here's your answer ~
https://www.google.co.in/search?q=R7+240
If even that doesn't work you then I guess you should remove the word gaming from the topic's title :rolleyes:
R0H1T
2,582
162
ZeroDivision
15
Yeah it's the one from the second link...Okay final question(s)!Will there be a bottle neck?And What about the FPS?
Aug 11, 2008
10,451
642
The R7 240 GDDR5 seems like a good choice for that cpu. As far a "bottlenecks" go, no matter what you will be bottlenecked by something, either the cpu or the gpu. The point is to not have a cpu or gpu that is vastly more powerful than the other. I think that 240 will be a good match for your cpu.
