Need help with PSU for my venice rig
slayek
190
Right now I am using an Antec 350W Smartpower PSU with the voltage/amp rating as below,
(+5/ 35A, +12/21A, +3.3/28A, -5/0.5A, -12/0.8A, +5 SB/2A).
If I total them down to wattage it comes down to more than 450 watts. I will be running 2 hdd, 2DVD-RW, 2 sticks of RAM, 3 PCI card and one 6600GT. Mobo is A8V delux and proc is AMD 3000+ venice.
Just wondering if I can run my system stable (without any OC) with my current PSU or I have to buy a new one?
TIA.
linjy2
319
it should work unless you got money to spend. i'm running alot more stuff on a antec tp2 380watt.
DaFOBulous1
4,065
You will need a stronger PSU imo...it's like a Camry on a 4-cylinder engine. It's alright in power but you are close to the edge.
mytechmafia
48
Same here. I also have the A8V Deluxe with the 3000+ Venice and I thought I was fine with a 380W PSU. But since I am OC'ing, I just upgraded to an Enermax 475W Noisetaker PSU. I don't got much, 9800 Pro, 1 HD, 2xRAM, 1 DVD-R, but since I don't even want to be borderline, I just went for it. I think you are close to borderline but will survive.
