Need help with Printer and Switch Box Please
Peabody
I would like to set up an additional(second) printer on my(non-networked) system. I have seen a setup some time ago where you could flip a switch from A to B on a small box connected to the system case to automatically select the printer to use for a given print job, so I figure that I may need one of those.Anyone know the techinal term for this small box and where I could purchase one? I also wonder if I could just install the new additional printer on LPT2 and change the default printer as I decided to use a particular printer.
Any other thoughts and/or ideas would be appreciated.
When you ask about installing a second printer on LPT2, are you saying that you already have a second parallel port installed on the system? If so, this is a no-brainer. You can choose printers via the GUI when it comes time to print from most apps, and you can just use the Settings | Printers dialog for changing the defaul whenever you wish to do so.
Even if you don't have a second printer port installed, you can:
1. Add a second one (if you have a free slot). The card is likely to be cheaper than the A/B Data Switch you're thinking of buying. It will also work better, since it's a more elegant solution as far as the OS is concerned.
2. Use a USB-connected printer as the second printer (assuming you have USB ports available that aren't already shared amongst too many higher bandwidth devices). Even if you have a parallel port style printer there are USB-to-parallel converters available. I honestly can't say how well (or badly) they may work, however.
Hope you find a good solution.
Regards,
Jim
