Need help with possible build
Cobalt
Wishlist
That is what I'm looking at as a possible build for my new PC. I'm on a budget so I'm trying to stay under $1000 the best I can. I'm happy with this list but I'm just not sure if the PSU that comes with the Sonata can handle everything? Should I add another PSU? Does the PSU that is included the newer unit with the 24-pin connector as some reviews say it is? The last thing I want is problems because of a weak PSU. Fast replies are appreciated as I may be looking to buy this within the next week or so. Thanks!
EDIT: Oh and comments/suggestions are appreciated as well. 😀
should be fine for running everything stock, but if you're going to be overclocking, you're going to run into a barrier and will need to buy a new psu if you want to go any further.. if you do plan on overclocking, i suggest getting the case you like without a PSU and get a PSU with AT LEAST 24A on the 12V rail... also you can get 2 of these http://www2.newegg.com/Product/Product.asp?Item=N82E16822148017R for about the same price as the one you're looking at 😉 seagate's warranty is awesome
