Greetings,
I'm pulling my hair out trying to find the best cooling option for my new system. Everytime I think I've found the best option, it's either impossible to find (a la TRUE), or it has some quirk that won't work for me. Here's my relevent MB/Case stats
GA-p35-ds4 rev2.0
Antec p182
Intel q6600 - g0 slacr
While I have it overclocked to 3.0ghz (333x9) using the stock Intel HSF, I'd rather get a better aftermarket one so maybe I could push it to 3.2ghz.
Here are my concerns though:
-It has to fit my case (obviously)
-I want it to be very quiet (noise > temp reduction)
-I hate the pushpin system, so I want it to have a mounting bracket type
-Weight concerns me as well (I don't want to have a 938g HSF in a vertical p182 tower)
-I prefer a HSF that has the fan on the side blowing air to the back of my case
-I prefer an automatic PMW(sp?) fan controller than one of those ugly manual ones - so I might need a 4-pin connector (or maybe the MB does the voltage reg control itself?)
I've looked over tons of HSF's to no avail (Scythe Infinity - too heavy, Zerotherm Nirvana - noisy/manual fan controller, T.R.U.E. - impossible to find, Artic Freezer Pro 7 - push pin, etc)
Is there any happy place that I can rest my weary head on and find the perfect HSF that meets the above requirements? Your expert knowledge is appreciated!
GA-p35-ds4 rev2.0
Antec p182
