Hey guys, haven't been on here for a while, but still this is my favorite forum for opinions and help. Anyway I'm moving soon and I'll be switching from using my 55 inch lcdtv as my monitor for my PC to a new monitor in the process. I've been mulling it for a while and here's what my requirements are:
I'm considering getting one of the new Nvidia Lightboost LCD monitors because the rig will be shifted from being both media and gaming to more of a focus on gaming. I've read a bunch of reviews and from what I understand the only two monitors available that support lightboost are the Benq Tx2040 line (24 inch for around USD500) and the Asus VG278 (around USD 700). If I go this route I'd take the BenQ I think because:
A) significantly cheaper frankly, I'm not looking to spend 700 for a new monitor
B) They say that 1080p on a 27 inch monitor is really not that great a resolution given the size and viewing distance
If I don't go the path of 3D, I want to spend around USD300-350 MAX. I know a lot of people reccomend the Dell 2412M because of the aspect ratio and great screen so that was one option, I also considered several 27 inch asus monitors (though I'm not sure about them simply because it means 1080P in that price range).
So basically my questions boil down to:
A) Anyone who's used a lightboost lcd for 3d gaming, do you think it's good? Is it worth the pricetag at around 500USD? The reviews I've read have been fairly positive, though some say you do lose some of the colorspace as a result of it (which I can live with, I don't do any design or such on my PC), and sometimes in previous generations issues with screen uniformity.
B) What would you reccomend for me in the 300-350 range for a new monitor? I'd like to take a minimum of 24 inch personally but if there's some amazing monitor at 22 inch in my range that is really THAT much better than the 24 inch at the same price I'd consider.
C) Do you feel that 27 inch at 1080P is really not a high enough resolution? I've never used a screen at that size or resolution before so I'm not entirely sure, but I saw a few reviews saying that so I'm somewhat worried.
For anyone that's wondering about my specs for the 3D gaming aspect my rig can easily handle anything:
i7 960 with overclock to 4.4ghz (normally I keep it at stock tbh though)
Dual Gigabyte GTX 580s 1.5GB
120GB OCZ Vertex 3 SSD
6 GB Ram
2x2TB WD drives (One is Green and one is Black)
the GPUs and CPU are liquid cooled using 2 360MM rads and 1 480MM rad so it's nice and quiet.
All opinions are very much appreciated, thanks guys!
6 GB Ram
