Need help with perl
shikhan
Hi guys,
I need some help on how to code something. I've got a script that does the following (in perl)
$continue = 1;
while ($continue) {
&dowork;
&sleep(600);
What I want is a clean way for the user to quit this program. If the user doesn't type anything, or presses keys other than, say, 'q', for the program to continue looping. I apparently can't use threads because when I tried, the script broke and said that this version of perl wasn't compiled for threads.
Any suggestions?
do while($_<>'q')
{ your stuff}
or
unless($_ = 'q')
do {whatever your stuff is}
The $_ should be the standard IO unless you've changed it
There are other ways & abbreviations ...
Good Luck
Scott
Originally posted by: ScottMac
do while($_<>'q')
{ your stuff}
or
unless($_ = 'q')
Good Luck
Scott
My &dowork subroutine does file parsing in which I use $_. But it is all inside the sub. Is it still okay to use what you said?
Plus, I'm getting a compile error when I try while($_<>'q')
