I bought this from eBay and I'm not sure how to install it...
https://www.ebay.com/itm/283050822203
PCI-E to External USB3.0 Port Power eSATA Internal USB 3.0 Header 9pin PCIe Card
Product Details
2 x USB 3.0 Port support transfer speed up to 5Gbps ( 1 external + 1 internal )
1 x PeSATA / USB 2.0 Combo Port ( External )
Low Profile bracket to fit HTPC or slim PC case
USB 3.0 :
Support Windows 8 UASP
No driver needed for Windows 8 ( do not install driver in Windows 8 )
Fully compliant with PCI Express Base Specification Revision 2.0
Single-lane (x1) PCI Express Throughput Rates Up to 4.8Gbps
Compliant with Universal Serial Bus 3.0 Specification Revision 1.0
Fully compatible with USB2.0 , USB 1.1
Transfer Rate: 5Gbps 480Mbps, 12Mbps
NEC uPD720202 Chipset
Built-in SATA Power Connector
PeSATA :
This 2 ports can be connected as eSATA, PeSATA, or USB 2.0.
Combine with our Power over ESATA cable ( not included in package ) , both 2.5" and 3.5 HDD can be supported without power supply from other sources.
Specifications :
Connect direct to SATA Hdd
Data transfer up to 6Gbps ( SATA III, depends on your mother board SATA port specification), and 480Mbps (USB 2.0 )
Supports WinXP, Win Vista and windows 7/8
Package contents :
1 x PCIE USB 3.0 / PeSATA adapter
1 x Driver CD
1 x Low Profile bracket
My mobo is an old Asrock M3A790GXH/128M that supports only USB 2.0 and SATA 2. I thought this product would allow me to use USB 3.0 and SATA 3 so I bought it. And now I have some questions:
1. I want to connect a 3.5" hard drive to the eSATAp port on the card. I will use an external power supply for the hard drive so I don't need to get the power from the eSATAp port. Can I use an ordinary SATA cable to connect the hard drive SATA port to the eSATAp port or do I have to use an eSATA cable?
2. Will I be getting 6 Gbps SATA 3 speed even though my mobo supports only SATA 2?
3. Will I be getting 5 Gbps USB 3 speed even though my mobo supports only USB 2?
4. It says "No driver needed for Windows 8 (do not install driver in Windows 8)." How about for Windows 7 which is my OS?
5. On the PCIE card circuit board itself there seems to be a SATA port and a SATA power connector. What are these for? Are these for connecting an internal hard drive to run it at SATA 3 speed?
Sorry that I have to post these questions here as there is no documentation and the eBay seller is so hard to contact or probably doesn't even know the answers to my questions.
Thank you so much in advance!
Product Details
- Package Dimensions: 5.5 x 4.1 x 1.5 inches
- Item Weight: 9.1 ounces
- Shipping Weight: 9.1 ounces
- Manufacturer: JiuWu
- Fully compliant with PCI Express Base Specification Revision 2.0
- Compliant with Universal Serial Bus 3.0 Specification Revision 1.0
- Single-lane (x1) PCI Express Throughput Rates Up to 4.8Gbps
- Transfer Rate: 5Gbps 480Mbps, 12Mbps
- NEC uPD720202 Chipset
USB 3.0 :
PeSATA :
Specifications :
Package contents :
1 x Driver CD
