TurboCooler
Hello,
While I am newly registered, I have been reading these forums for years.
I am hoping someone can help.
My parents are retired and in their mid to late 60s. My dad loves his computer and is a self taught geek. While most of the things he does are surf the web and watch Slingbox and Netflix on his computer. There is one thing he does the most -- photography -- With that he is big into Photoshop and Lightroom.
My dad insists he wants Windows 10 when it comes around. However, his drives are old SATA II drives and he needs more disk space to even attempt to upgrade.
I was thinking of getting a PCI SATA III card and then upgrade his main hard drive to WD Cavier Blue 1TB Drive. However, I cannot find a review on PCI SATA III Cards that work well.
Whatever solution, I would love to just keep his case to save money.
Any help would be appreciated, thank you
Here is his setup:
HWiNFO64 Version 4.62-2500
DELLT3400 -----------------------------------------------------------------
[Current Computer]
Computer Brand Name: DELL Precision WorkStation T3400
[Operating System]
Operating System: Microsoft Windows 7 Professional (x64) Build 7601
Service Pack: Service Pack 1
UEFI Boot: Not Present
Central Processor(s) ------------------------------------------------------
[CPU Unit Count]
Number Of Processor Packages (Physical): 1
Number Of Processors Cores: 2
Number Of Logical Processors: 2
Intel Core 2 Duo E8500 ----------------------------------------------------
[General Information]
Processor Name: Intel Core 2 Duo E8500
Original Processor Frequency: 3166.7 MHz
Original Processor Frequency [MHz]: 3167
CPU ID: 00010676
CPU Brand Name: Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz
CPU Vendor: GenuineIntel
CPU Stepping: C0
CPU Code Name: Wolfdale-H
CPU S-Spec: SLAPK
CPU Thermal Design Power (TDP): 65.0 W
CPU Max. Case Temperature (Tcase_max): 72.4 °C
CPU Type: Production Unit
CPU Platform: LGA775 (FC-LGA8)
Microcode Update Revision: 60F
Number of CPU Cores: 2
Number of Logical CPUs: 2
[Operating Points]
CPU LFM (Minimum): 2000.0 MHz = 6.00 x 333.3 MHz @ 1.0000 V
CPU HFM (Maximum): 3166.7 MHz = 9.50 x 333.3 MHz @ 1.1750 V [Locked]
CPU Current: 3158.4 MHz = 9.50 x 332.5 MHz @ 1.1750 V
CPU Bus Type: FSB (QDR)
[Cache and TLB]
L1 Cache: Instruction: 2 x 32 KBytes, Data: 2 x 32 KBytes
L2 Cache: Integrated: 6 MBytes
Instruction TLB: 4 KB Pages, 4-way set associative, 128 entries
Data TLB: 4 MB Pages, 4-way set associative, 32 entries
[Motherboard]
Motherboard Model: DELL 0TP412
Motherboard Chipset: Intel X38 (Bearlake-X) + ICH9R
Motherboard Slots: 3xPCI, 1xPCI Express x1, 1xPCI Express x4, 2xPCI Express x16
PCI Express Version Supported: v2.0
USB Version Supported: v2.0
[General information]
Total Memory Size: 16 GBytes
Total Memory Size [MB]: 16384
[Current Performance Settings]
Maximum Supported Memory Clock: 533.3 MHz
Current Memory Clock: 399.0 MHz (6 : 5 ratio)
Current Timing (tCAS-tRCD-tRP-tRAS): 5.0-5-5-15
Memory Runs At: Dual-Channel
Command Rate: 2T
Read to Read Delay (tRD_RD) Same Rank: 4T
Read to Read Delay (tRD_RD) Different Rank: 6T
Write to Write Delay (tWR_WR) Same Rank: 4T
Write to Write Delay (tWR_WR) Different Rank: 6T
Read to Write Delay (tRD_WR) Different Rank: 8T
Write to Read Delay (tWR_RD) Same Rank (tWTR): 11T
Write to Read Delay (tWR_RD) Different Rank: 5T
Read to Precharge Delay (tRTP): 3T
Write to Precharge Delay (tWTP): 25T
Write Recovery Time (tWR): 14T
RAS# to RAS# Delay (tRRD): 3T
Refresh Cycle Time (tRFC): 78T
Four Activate Window (tFAW): 14T
Row: 0 - 4096 MB PC2-6400 DDR2-SDRAM G Skill F2-6400CL5-4GBPQ -------------
[General Module Information]
Module Number: 0
Module Size: 4096 MBytes
Memory Type: DDR2-SDRAM
DIMM Type: Regular Unbuffered (UDIMM)
Error Check/Correction: None
Memory Speed: 400.0 MHz (PC2-6400)
Module Manufacturer: G Skill
Module Model: F2-6400CL5-4GBPQ
Serial Number: N/A
Manufacturing Date: Unknown
[Module Characteristics]
Module Width: 64-bits
Module Voltage: SSTL 1.8V
SPD Revision: 1.2
Number Of Ranks: 2
Row Address Bits: 15
Column Address Bits: 10
Number Of Banks: 8
Here is his setup:
[Current Computer]
[Operating System]
[CPU Unit Count]
CPU ID: 00010676
CPU Stepping: C0
CPU S-Spec: SLAPK
[Operating Points]
[Cache and TLB]
[Motherboard]
Command Rate: 2T
Module Number: 0
Serial Number: N/A
SPD Revision: 1.2
Number Of Ranks: 2
Number Of Banks: 8
