Need help with p4 connections
lastig21
2,145
When I had my Athlon setup, I cut the wires for the p4 connectors to get them out of the way. I will be putting my Northwood setup together this evening, and need to solder the connections back on. The 6 wire connection has 1 red, 2 orange, and 3 black wires. As long as I match colors, will everything be ok even if I don't get the wires hooked up exatly as the psu came? I have the same question on the 4 wire plug. It has 2 yellow wires and 2 black wires. Can I accidentaly swap the 2 black or 2 yellow wires and everything be ok?
Thanks in advance
panhead49
1,880
same-e same-e..................yellow to yellow............black to black...........cant go wrong.....
