- Aug 12, 2007
- 1,100
- 0
- 0
Ok so I have an optoma hd33. I need three things to go along with this. Now I have looked but its kind of confusing so i figured I would ask you guys.
1. The correct bulb with casing
2. The correct glasses. (do I need an emitter I think mine came with one.
As for the bulb I can find them online but the problem is I dont know if they come with the casing intact. Or if its just the bulb. See I read somewhere that the casing doesnt always come with the bulb. I keep finding bulbs that are anywhere from 117 dollars to 310 dollars. I assume taht the more expensive ones come with the case but I dont wanna make a mistake and get it wrong. End up spending 300 dollars for something I cant even use.
The 2nd thing is the 3d glasses. Know I am pretty sure my hd33 came with an emitter so I shouldnt need one. See I can find glasses for 50ish bucks but I keep finding glasses with an emitter for 120 bucks. Now I dont wanna buy the wrong thing end up spending cash one something that wont work or I dont need.
Any help with this would be much appreciated. Like I said I just dont wanna f things up and spend money on something I dont need. I have done that in the past and its very aggrovating.
