BlackDragonX
Hey guys, I have a problem and need some help. First let me tell you about my system:
Asus A8N-SLI Premium
AMD X2 4400+
2Gb of Corsair TWINX1024-3200LLPRO (512mb X 4)
XFX 7800 GTX Overclock(only 1 card for now)
WCD 74Gb Raptor
The system works great , but I of course want to push it. I did some reading on overclocking the X2 4400 and decided to overclock mine. So here is my problem
iF i leave the memory settings on AUTO I can push the CPU as far as I want, but the system defaults the memory to 333Mhz so my 3dmark05 scores drop by almost 1000 points. As soon as I try to set the memory manually the system wont boot. The best I got it to do was
CPU = FSB 212 @ 1.375 Volts
Memory = 2.3.2.6 @ 2.9 volts (at lower voltages the memory is not stable)
which gives me 2.33Ghz, but this is nothing compare to what others have gotten.
Any ideas? I had the same menory in my oder system and I was able to get it to 220Mhz at 2.8volts and timings of 2.3.2.5.
Thanks in advance for your help guys.
AMD X2 4400+
WCD 74Gb Raptor
