dariushou1
Hello, any help with the following setup would be greatly appreciated. Here are my drives and the planned setup for tomorrow.
Hard Drives:
(4) Fujitsu 18.4GB 15K RPM ULTRA160 SCSI (MAM3184MP)(68 Pin)
(1) Seagate Cheetah 9.1GB Ultra160 SCSI (ST39205LC) (80 Pin)
(1) Fujitsu 9.1GB Ultra160 SCSI (MAH3091MC) (80 Pin)
SCSI Controllers:
(1) 3400s Adaptec Scsi 4 channel Ultra160 SCSI Raid Card
(2) 39160 Adaptec Ultra160 SCSI Card (2 independent Ultra160 Channels)
The Setup:
3 Fujitsu 18.4GB 15K RPM ULTRA160 SCSI drives on 3 of the channels on the 3400s in RAID 0. They will be partitioned with a 1.5 gig swap file first followed by partitions for apps, video, audio, games, etc?
The other channel on the 3400s card will be setup in RAID 0 consisting of:
(2) Fujitsu 9.1GB Ultra160 SCSI (MAH3091MC) (80 Pin)
These drives will be partitioned for video and audio spillover files.
As far the last drive (Fujitsu 18.4GB 15K RPM ULTRA160 SCSI) it will go on it?s on channel on the 39160 Adaptec Ultra160 SCSI Card. The operating system will be on this drive with a 1.5 gig partition.
Questions:
(1) I?ve never partitioned a drive before. I have partition magic 7.0. Do you partition before installing windows or after it is installed.
(2) Do I keep my data files for say photoshop or excel on a separate partition than where the apps are installed.
(3) This is my first time to setup a RAID Array also. Is it best to go ahead and install Windows XP and then set it up.
(4) Any comments on the hard drive placement and further setting up the partitions or any area of this setup for performance would be greatly appreciated.
Last note:
OS: WindowsXP
RAM: 1GB RIMM4200
CPU: P4 3.06Ghz
Lots of video editing, rendering, capturing. And the usual games, multitasking, etc?
Thanks in advance.
Hard Drives:
SCSI Controllers:
The Setup:
Questions:
Last note:
OS: WindowsXP
RAM: 1GB RIMM4200
CPU: P4 3.06Ghz
Thanks in advance.
