Need Help with New Build
AshHouseWares
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
This PC is meant to be an "end all, be all" sort of PC for me. It's going to be used for coding, video editing, streaming, and gaming. It's also going to be utilized for a home office for my job. I'll be spending 14+ hours per day at this PC for the next few months.
I want to be able to play all current titles as well as titles that will be released over the next two year span at ultra.
I will be editing large video files and occasionally editing photos, but not often.
I will also be using this PC for work. That means I'll need plenty of screen real estate. My work isn't CPU intensive, graphic intensive, or requires anything special other than screen real estate. I'm not talented in organization AND multitasking. Therefore, it's imperative to me and my productivity that I have adequate screen space to have various programs and documents opened at the same time and view able at a glance. I lose time searching for windows/programs that are open when the on-screen clutter is thick. When I'm in the zone, little distractions like not being able to immediately find an open program or document immediately result in my productivity decreasing. I've found that I have a difficult time getting back on track after I lose momentum. So, the multi-monitor aspect is crucial to me. When working, I have all my documents and programs that I use in the exact same spots on the screen every single time.
My desk is 72" x 30". Made it myself, pretty proud of it. So I have a lot of desk space.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
I'm willing to invest a good chunk of cash into this project. Right now my absolute max budget is $6,000. If needed, I would be willing to bump that up another thousand if necessary. However, unless you believe some component would make an absolute impact on user experience, I'd prefer to stick to $6,000.
3. What country YOU will be buying YOUR parts from.
I live in the United States and will be purchasing my items from within the United States.
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
Not currently applicable.
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
I've always utilized Intel. However, I'm willing to utilize AMD if necessary. From the charts I've seen, I think Intel would be the best bet. Graphics cards will need to be Nvidia based as the central monitor will likely be the Acer X27 Predator. I want to utilize that G-Sync. No preference for SSD/HDD brands.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
My current components will be given to a family friend's son. The boy's a genius (by my standards anyway). You gotta fan that flame!
7. IF YOU plan on overclocking or run the system at default speeds.
I will be OCing.
8. What resolution, not monitor size, will you be using?
Here's the kicker. The main monitor (can be changed if I see some valid reasons) is 4K. If I'm gaming, this will be the only monitor that's being utilized. However, I would like, at minimum, two additional monitors. One on each side of the main monitor. These will be utilized for work, multitasking, etc.
9. WHEN do you plan to build it?
I would like to start ordering my parts sometime early next week.
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
I already have a spare copy of the OS set aside for this project.
whm1974
9,436
1,572
If you are going to use this system for work then I advise you not to overclock as this may cause problems. As far as playing current and future titles at ultra get the 1080Ti.
For video editing the more cores the better. Take a look at the Ryzen 1800x or Intel's HEDT platform, or maybe the Intel Xeon CPUs.
Smoblikat
5,184
107
https://www.newegg.com/Product/Product.aspx?Item=N82E16813132505 - Motherboard, $400
https://www.newegg.com/Product/Product.aspx?Item=N82E16819117645 - CPU, $1050 ( https://www.newegg.com/Product/Product.aspx?Item=N82E16819117643 ) you could also get this one, but I dont think the jump in price reflects the slight performance benefits, though it does have 4 more threads.
https://www.newegg.com/Product/Product.aspx?Item=N82E16820232329 - RAM, $510. You could also bump up to the 128gb kit for twice the price if you wanted, but im not sure how necessary that would be, 64gb is already a lot of memory.
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487338 - GPU, $780. I dont know if/how well SLi scales for media work, but you could pick up 2 of these and it might help out when gaming, especially in the future, but that is very much not required.
https://www.newegg.com/Product/Product.aspx?Item=N82E16817139204 - PSU, $200. 1000W should be plenty, even if you decide to go for 2 GPU's.
https://www.newegg.com/Product/Product.aspx?Item=9SIA0ZX5M51020 - Case, $190. This is really up to you, but this case has great cooling and should fit everything youre looking for.
https://www.newegg.com/Product/Product.aspx?Item=N82E16835181100 - Cooler, $140. This thing should be a monster, you can grab some LED fans for it too if thats your thing, I always liked the coolermaster sickleflow ones.
https://www.newegg.com/Product/Product.aspx?Item=N82E16820147597 - 1TB M.2 SSD, $630. Use this drive as your main OS drive and do your media work off of it, its going to be fast AF and a 1TB capacity should (hopefully) be more than enough. There is a 2TB variant available also if you think its necessary.
https://www.newegg.com/Product/Product.aspx?Item=N82E16822235128 - 4TB HDD, $210. This is mainly for archival storage, but is fast enough that you could also put some games on it as well if needed.
https://www.newegg.com/Product/Product.aspx?Item=N82E16824022246 - Monitors, $800. Get two of these 28" 4K screens, should have plenty of real estate and since theyre also 4K you wont run into any strange scaling issues trying to run different resolutions at the same time.
All totaled up as it sits, thats about $4010, which is under your budget by a decent amount, and it would make basically anyone who sees it instantly jealous. Just for fun, I calculated the cost for what the most extreme configuration would be (128gb RAM, 2tb SSD, 2X GPU's, 10 core CPU etc..) and at the absolute bleeding edge of performance, youll be paying about $6500 for a 100% no compromise, best of the best, literally salivating right now thinking about it, computing monolith. Personally I dont recommend going down that road, the additional $2500 in cost isnt worth the (technically huge, but noticeably not) jump in performance. Good luck with the build, if you do wind up building this thing, make a thread with some sexy benchmark runs and pictures.
EDIT - Also, you can save a tone of money on your car insur-, oh wait, nvm. But seriously if you dont mind technically not having the best of the best, you can save some serious coin by going with an AMD based system.
https://www.newegg.com/Product/Product.aspx?Item=N82E16813132963 - Mobo, $255
https://www.newegg.com/Product/Product.aspx?Item=N82E16819113430 - CPU, $500
That alone saves you $700, and leaves you with the same amount of cores/threads, and all of the other components listed are compatible with this setup. Though this board is effectively limited to 64gb RAM, while the intel one could easily go up to 128gb without having to buy 32gb DIMMs. Look up benchmarks of the two CPU's I mentioned running whichever games/applications youre planning on using, both are good options, but im guessing the intel one would perform at lieast slightly faster clock for clock.
Dr. Swag
PCPartPicker part list / Price breakdown by merchant
CPU: AMD - RYZEN 7 1700 3.0GHz 8-Core Processor ($313.99 @ Amazon)
CPU Cooler: NZXT - Kraken X62 Liquid CPU Cooler ($158.99 @ SuperBiiz)
Motherboard: Asus - CROSSHAIR VI HERO ATX AM4 Motherboard ($243.99 @ SuperBiiz)
Memory: G.Skill - Trident Z 32GB (2 x 16GB) DDR4-3200 Memory ($321.99 @ Newegg)
Storage: Samsung - 960 EVO 1TB M.2-2280 Solid State Drive ($479.99 @ B&H)
Storage: Western Digital - Gold 4TB 3.5" 7200RPM Internal Hard Drive ($188.99 @ SuperBiiz)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING Video Card (2-Way SLI) ($744.99 @ SuperBiiz)
Case: Corsair - Crystal 570X RGB ATX Mid Tower Case ($162.86 @ Newegg Marketplace)
Power Supply: SeaSonic - PRIME Gold 1000W 80+ Gold Certified Fully-Modular ATX Power Supply ($167.99 @ SuperBiiz)
Other: Predator X27 ($1800.00)
Total: $5328.77
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2017-05-06 09:21 EDT-0400
Leaves $650 for two other monitors.
Or if you feel the need for 64gb ram you could get two of the kit and have $300 for the two monitors.
I don't know what you want for the other monitors (resolution, size, refresh rate, etc.) so I won't make suggestions.
