Proprioceptive
My wife is breathing down my neck about replacing our aging Gateway desktop. I'd rather build myself since I can, and to my knowledge, it's still a bit more bang for your buck than buying from HP/Dell etc. I just simply don't have the time right now to research what the latest components are and the best configuration to purchase would be. I know it's annoying to have someone just ask you guys to design a build for them, but if you've got the time and interest to help someone out, I'd appreciate it. As requested, I'll provide as much information as possible below:
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
- Everyday home computing, online videos, tv shows, light gaming... I'd like to be able to play modern games without going crazy with the settings. I just want them to be playable at a decent framerate and performance. I don't game a whole lot, but it's a nice escape. One of the most important aspects, is that this PC needs to be QUIET! Our current desktop sounds like a jet engine.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
- peferably around $400-500
3. What country YOU will be buying YOUR parts from.
- US
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
- I want the best bang for my buck... I'm no fanboy.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
- monitor, mouse, external wifi adapter, speakers, webcam, external HD, OS,
6. IF YOU have searched and/or read similar threads.
- yes
7. IF YOU plan on overclocking or run the system at default speeds.
- default speeds... not messing with OCing
8. What resolution YOU plan on gaming with.
- 1680x1050
9. WHEN do you plan to build it?
- NOW
Basically, I need help with these items:
Power supply
Case
Motherboard
CPU
Heatsink/fan for the CPU
Memory
Primary hard drive <--- 1TB or greater
Primary optical drive <--- possibly a BluRay drive if it's manageable with budget
Video card (unless you?re using onboard video)
...anything else you think I may be missing.
- US
- yes
- 1680x1050
- NOW
Power supply
Case
Motherboard
CPU
Memory
