need help with networking ASAP
cchen
6,062
I need to connect two computers together. One is running nt server, one is running win2k pro. i'm trying to connect using their ethernet cards with a crossover cable. I set up both boxes to use dhcp, which should give them their own ip addresses correct? the data is on the computer running nt server. when i connect them, and check the status of the local area network, it says that it is connected, but when i look to see what computers there are in the network, none show up. how can i make the other computer show up?
the drives that i need to access on the nt server computer are already configured for sharing...
Pepsi90919
Unless they're both running a DHCP server, using DHCP to get an IP address isn't going to work. Assign them 10.0.0.1 10.0.0.2 or something.
iamwiz82
30,772
13
<< Unless they're both running a DHCP server, using DHCP to get an IP address isn't going to work. Assign them 10.0.0.1 10.0.0.2 or something. >>
agreed, just assign them a static IP.
guyver01
22,135
61
not necessarily...
if they're running DHCP, and no DHCP server is detected... they should get and IP within then 169.254 range.... so they can still communicate ;)
RSI
7,281
Yeah, I use 192.168.0.1 and 192.168.0.2... you could use the other ones suggested. Just specify your own IP address. Why would you want it automatically fetched? Just adds more lag.
-RSI
