TheJetPlane
Hi guys, im looking to switch from console to pc but have no knowledge on what is required. i see alot of people making "gaming pc" for under $350, but i dont know how reliable that would be for games like BF4 and DayZ.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
-pure gaming. Ex. BF4 & DayZ
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
-my budget is $350
3. What country YOU will be buying YOUR parts from.
-US
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
-N/A
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
-AMD
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
-None
7. IF YOU plan on overclocking or run the system at default speeds.
-no overclocking
8. What resolution, not monitor size, will you be using?
-not really sure.
9. WHEN do you plan to build it?
-when i have everything ready.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
-my budget is $350
-US
-N/A
-AMD
-None
-no overclocking
-not really sure.
